Results 1 to 10 of 24
Thread: Broken front suspension
    Regular Member Ratty Dad's Avatar
    Rochdale England
    confused Broken front suspension
    hi guys hope you can help!
    my front, drivers side spring has snapped.......
    do i?
    a: replace one spring?
    b: replace front two?
    c: replace all four?
    D: can i do it myself?
    e: buy parts and pay for labour?
    z: just go straight to a garage and get em to do the lot??
    not after anything fancy, just want my suspension sorted again.....
    any ideas????
    preston
    Garages will tell you to change the pair, I've have done mine in the past and have just replaced the broken one, you'll need spring compressors to change them as well as tools to remove the macpherson strut.
    preston
    Lower ball joint off, brake caliper off, driveshaft nut to undo, track rod end to disconnect, top of macpherson strut to undo (engine bay) then remove from car and change spring. doddle!
    Jul 2006
    Mexico
    Change if possible all four springs...if not possible at least both fronts. Go for a none VX brand...apparently they are brittle as glass.
    You can do it yourself if you have the tools.
    Rochdale England
    cheers for the prompt replys keep em coming!
    just found four apex sports for £92.50 any good?
    any ideas?
    know any good breakers?
    second hand ok?
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    what model is it mate
    Rochdale England
    its a 04 ls
    preston
    what are apex sports, can't see the reason for changing all four unless you like work!
    Rochdale England
    don't really wanna change all four......... just found em on the net!
    don't know much about suspension!
    Apr 2006
    Wigan
    Quote Originally Posted by Ratty Dad View Post
    its a 04 ls
    petrol , diesel engine size
  1. front wipers broken
    By Anna23 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th December 2009, 20:13
  2. broken front springs
    By 30ltr nutter in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2009, 20:34
  3. broken suspension
    By s2racer in forum Suspension, Wheels & Brakes
    Last Post: 7th November 2008, 16:47
  4. Broken Suspension Spring
    By 2.0 DTI SXI in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 07:56
  5. symptoms of half broken suspension springs
    By ozzye in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 22:59
