Results 1 to 3 of 3
Thread: Engine looses pawer at 2000 rpm
    Kingston Upon Hull
    Default Engine looses pawer at 2000 rpm
    Hi all a mate has a 2l diesel vectra c and when he gets to 2000rpm in all gears the engine stops reving he has cleaned the ERG and replaced the mass air valve twice + the boost valve
    It has cost a fortune at the main dealers and its the same as when it went in
    Can anyone help with what to look at next
    Thankyou for looking
    Graham
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Firstly check all the large hoses that run from the turbo to the exhaust manifold via the intercooler for splits etc , secondly check the vacuum hoses and the connectors for splits /perishing at the same time test to see if the vacuum actuattors are actually working, should be able to detect a very light suction with a wet finger , its only 0.6 bar when working properly
    hope this helps bob
    Kingston Upon Hull
    Bump, more help please
    Thankyou
  1. Y30DT Looses boost, clear fault code and back to normal!
    By tommychimp in forum Y & Z30DT Specific
    Last Post: 5th September 2011, 20:07
  2. £2000
    By japeye86 in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2010, 23:04
  3. Weak engine under 2000 rpm - cdti 120
    By zafira in forum Diesel Engine related
    Last Post: 29th November 2010, 21:24
  4. Engine Judder 2.0 DTI at 2000 revs
    By cp123 in forum Engine & Drivetrain
    Last Post: 16th January 2008, 17:38
  5. S 2000
    By JCB in forum Cars for sale
    Last Post: 23rd September 2005, 13:32
