Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Can`t turn of headlights
    Norway
    confused Can`t turn of headlights
    I hope this ends up in the right subforum..
    4 days ago i bought a Vectra C, 2002, but on that first model of this car, the headlights can`t be turned off.
    (Picture found at http://www.ledconversions.co.uk/acat...dual_Kits.html)
    When the lightsvitch is in "0"-position the lights comes on when I start the car, but the dashboard-lights are off.
    In the midle-position the headlights should turn off, but they don`t, but now the lights in my dashboard is on.
    And in the right position the headlights should come on again. But..they don`t.....
    Is it as simple as pulling out this svitch, and cutting the headlight-wire that is on the midle position, or do I need to replace the control-unit for my headlights ?
    Does anyone have a picture of this lightsvitch from behind ? I don`t want to pull it out, if I can`t do anything in there..
    It could be nice to be parked somewhere, with the engine on, and lights off...
    Is it not daylight lights fixed in an EU country, what is the law in Norway? ..
    Norway
    The law in Norway says that headlights should be used when driving.. but it doesnt say anything about lights on when parked. Thats the issue here.. I want to turn my headlights off, and use only the 5w-light in there, when I`m parked. I guess it is like this from the factory, but I don`t want to have it this way.. and from 2003 the headlights CAN be turned off..
    I hope, and think, that the lightswitch is as simple as just pulling of one wire on the back of it, but I`m not sure.. can`t fint a picture of it anywhere..
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    think it can be tech2 at the dealer to turn daylight running lights off
    Sure someone on here will be able to help you m8 just hang in there. ..
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    aarrgg your yo didnt work fix it!
    Norway
    I talked to the dealer, and he first belived that it could be a computer-fix to this, just hook up a computer to the car, and voìla.. but no. He called me to day, and said that this could be fixed, but I had to replace the control-unit for my headlights, but what HE mean with control-unit, I don`t know.. if it is the light-switch, or some magic black-box somewhere in my car.
    But it sounds expensive.. so if I just can find a picture that can show me how the switch looks from behind, I will be able so see if it is a simple fix with a wire-cutter, or if it is a expensive fix... My guess is that is one wire on the "0"- and one on the midle- and one on the right-position. Cutting the one in the midle will turn the lights off, but leave the parking-lights on... I hope.
    milton keynes
    What you need to do is take the front off with a flat blade driver , there are 8 clips holding it in place.
    Next take the 5 torx screws out .
    Then the light switch part can be taken away from the other half.
    Now turn the light switch part 1 click clockwise , put it back on the main body and try again , I wouldnt put the screws back in until you have the switch in the correct position.
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    vectracclub, think id just leave it the way it is to be honest, i always drive with headlights on - tho i do see the parked problem if you like the heaters on whilst dogging hahaha
    Quote Originally Posted by Morephun View Post
    Hows that. . .
  1. Turn me on........
    By farmboy91 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2011, 15:23
  2. It Is Now My Turn
    By RobW in forum General Chat
    Last Post: 16th August 2011, 22:22
  3. NOt his turn
    By silverhairedracer in forum General Chat
    Last Post: 19th April 2010, 15:36
  4. What happens if i turn this ?
    By Vectra-c-SRI in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 22:37
  5. Must be my turn...
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2006, 17:42
cant turn off lights when car is running vectra c
