Hi guys,iv got a big scratch across the windscreen where i must have got a small stone caught in it. Is very fine but at the same time very noticeable. Can these be removed or is a new windscreen on the cards?
Cheers.
Cheers.
- wouldnt mind knowing this myself
Forgot to add it was caught in the wipers so its all the way across the windscreen.
not 100% certain but I think its just chips that can be filled, scratch is not a crack but if its in your line of vision I'd imagine it would be an MOT failure?
yeah i thought that.
Depending on how deep it is T-cut do a glass polish which is quite good. Failing that try some of the windscreen guys for a solution
You can buff them with jewellers rouge , like a rubbing compound for glass.
Ask your local windscreen repairer.
You could get it replaced if you have windscreen cover by paying the excess , normally £50 or £60 if your fully comp.
Or try this - http://cgi.ebay.co.uk/NEW-Windscreen...1%7C240%3A1318
A glass fine abrasive polish gets fine scratch's out,
better to use an electric polisher though, takes some
elbow grease to move the smallest of marks ! !
ok cheers guys
