Thread: EGR Flow fault?
    Default EGR Flow fault?
    1.9 CDTI 150.
    Car has been standing for a week, and when started today it threw up a code.
    P0400 Generic EGR flow malfunction.
    Cleared the code but keeps coming back, is it time to strip the EGR valve and clean it?
    Or am I looking at something else?
    Andy
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    I had that same code appear on my old 56 plate 150 vec, and yes a replacement EGR (under warranty in my case) fixed it.
    If the cars out of warranty, I would certainly use the forums excellent How-2 and give it a clean first, could save you a bit of money.
    Probably full of deposits and stuck for the very reason its been standing a few days.
    Ok thanks, I'll give it a clean this afternoon.
    Andy
    Stripped, freed off, cleaned, lubed and re-fitted in less than an hour.
    And what a difference it has made.
    Great write up on the how 2.
    East Yorkshire
    Even if the computer isnt saying a fault / dirty valve could it still need a clean. I have a 2004 2.2dti Elite and I get an occassional bad smell into the car and its been suggested that the EGR valve could be causing the problem.
    Was it as simple as the how to guide says?
    even for a chap who never tinkers arround under the bonet apart from adding water and cleaning.
    It's worth checking it, but as to how easy it is to do someone else better answer that as I am an engineer so it was a doddle to me without reading all the guide.
    I would say it's possible for anyone to do it, just take your time and if you get stuck, post on here and someone will advise you.
    Mine was siezed solid and thats why the error code was flagged up asit wouldn't open at all.
    I think you would get restricted movement at first and that will cause enough problems.
    Andy
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    it is sooo easy mate to do,
    and as mentioned above the cars feels so much better
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    agree bud its a easy fix and not a bad job to do
    Birmingham
    Quote Originally Posted by andy-b View Post
    And what a difference it has made. Great write up on the how 2.
    When you say "lubed"..what exactly do you lube it with...wd40, grease, oil??...and do i need to becareful exactly where i put the lube on the EGR or can i apply it generously pretty much anwhere on the EGR?
    Copper grease - anti sieze compound.
    The egr itself will probably be free moving, it's the shuttle inside the solenoid that sticks.
    Andy
  1. air flow meter
    By tyler boy in forum Engine & Drivetrain
    Last Post: 17th November 2011, 22:20
  2. Signum air flow meter fault 2.0t
    By kirby in forum Engine & Drivetrain
    Last Post: 14th October 2011, 00:16
  3. air flow meter
    By bulldogblu in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 12:44
  4. Mass Air flow Sensor fault
    By stroake in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2009, 12:34
  5. Air flow problem?
    By siz1 in forum Engine & Drivetrain
    Last Post: 10th December 2008, 02:49
