Thread: creaking from front end
    liverpool
    Default creaking from front end
    can some one help me please i have a problem with my car when i brake slowly i get a loud creaking noise which seems to be coming from the front it only does it when i brake and only seems to be until the brakes have fully warmed up then it goes away.
    Mileage : 000
    I don,t know about the brakes "bit". But there is a bit of a thing where you can get a noise from the radiator mounts, and the coil spring seats can make a noise too.
    liverpool
    it only makes the noise when i apply the brake gently and then as i get down to about 10mph i get the creaking once i have used the car for a while it doesnt do it also there is no problems when going over speed bumps so am thinking the problem is coming from the brakes
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Creaking from brakes..... could they be sticking..?
    Usual front end noises (like said above) are usually caused by spring seats, radiator mounts and drop links.
    Maida Vale
    The spring seat problem doesn't cause a creaking, it causes a loud "twang" that sounds like someone's hitting the underside of the chassis with a hammer - when you hear it you wouldn't even guess it was coming from the suspension.
  1. creaking front end
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2012, 11:15
  2. creaking from the front
    Last Post: 11th October 2009, 19:24
  3. creaking front end
    By peadar in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2009, 22:13
  4. Creaking from front
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 8th December 2008, 22:16
  5. Creaking from front - 03 1.8 SXI
    By addyboy1982 in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2007, 21:14
