got my new wheels on today, bu tnow my boot wont open - if i eave it locked for 5 mins and unlock it half opens but when you press the door release handle at the back it doesnt make the whirring noise anymore!!!
Sorry, its still locked or the "push" release button doesnt work?
its doesnt open lol, the push buttons on the fob and drivers door work, the boot button on the boot itself doesnt make the whirring moter noise when you press it
right, opened the back fusebox and a fuse was missing, replaced it and the boot opened twice, now it wont open again and the fuse isnt blown !!!! any ideas please!!!!!
The mciro switch in the handle is probably stuck. Think there is a how 2 on this as Duncan had the problem. You can open it from the inside with the key.
WD 40? ..
big sig, is there any way I can test it? seems strange that after replacing the fuse the first time it worked....
i dont want to rip the car to bits if its a prob somewere else like a loose wire ect no aberdeen living sig drivers with skills? lol
Maybe the switch is shorting out causing the fuse to go? TBh That is where I would look first but I may be wrong. I haven't read anything else I don't think about siggy boot opening problems.
