Thread: Car problem
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Car problem
    My father in law has a starting problem with his car.
    The car is a Proton something or other, and its S reg.
    The car simply wont start, and no instrument lights when the key is turned, however you can hear the starter motor going and all external lights work.
    Tried jump starting it for some reason, as he was adamant his battery was goosed, but the fault remained the same.
    Any ideas?
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Maybe the elastic band is broke .
    Is the engine turning over or does the starter motor just click when the key is turned
    Mar 2007
    Grimsby, Lincs.
    sounds like it is turning over. the belts look okay mate.
    from an aircraft leccy point of view it looks like an electrical problem. my idea is to test all the fuses i can find tomorrow and take it from there.
    May 2007
    WINSFORD
    Well if its turning over its either no spark or no fuel so first check would be to take a plug out and see if its wet with fuel and then check for a spark
    Mar 2007
    Grimsby, Lincs.
    cool. why no lights on dashboard then?
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
