Results 1 to 10 of 13
Thread: engine oil
    Regular Member Rob W's Avatar
    north yorkshire
    Default engine oil
    have checked oil level for past 2 months and topped up with full synth
    even before top up i noticed this residue on rocker cap
    oil on dipstick looks fine
    is this normal
    I could be wrong but isn't that a sign of the water and oil mixing. Or the mixing of two different grades of oil.
    I'm sure someone will be along with a definate answer for you soon though.
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    I think its called..emulsification..older fords and rovers suffered with it and I think its caused by condensation in the engine ??. I maybe wrong so dont take this as gospel. If it was my car Id pop into the dealer and get it checked over..having said that I know some one with a mazda rx8 with the wankel engine which has this problem and the mazda dealer said it was o.k.......
    Rob W..
    From your picture i can see you run a 3.2..
    I had this emulsification on the filler cap, so I asked my mate at VX luton about it.. He said that it's because the filler neck is so long on the 3.2 as against the 2.5/2.6. The oil vapour doesn't get as hot by the cap as it's 3 inches above the heat source, so when the atmospheric moisture mixes with the oil vapour it doesn't burn off..leaving 'mayonaise' on the filler cap but not over the inside of the cam covers.. Most 3.2's have this prob..long hard runs are the only way to get it hot up there.. I just wipe mine occasionaly..
    So no head gasket failure..Just poor design..If you don't like it fit a front bank cam cover from a C25XE..the filler is accessable and close to the engine..
    Nice ultra blue by the way..
    north yorkshire
    Smile
    thx for help
    Rob
    Apr 2006
    Bristol
    I have the same problem with my 3.2 but i do a lot of short runs, so the engine is not getting hot.
    Mileage : 000
    Yes that is all it is short journeys, if you give your car a good run on the motorway it will do it the world of good and remove that emulsified gunge, I get it on my 3.2V6 too, but it gets rid of it when it has been on the motor way, it should not do any harm.
    north yorkshire
    Default vwa lah
    did a 300 mile round trip today and
    problem gone
    in the past i've only checked oil and rocker cap before a long journey!!.
    thanks to everyone for help.
    Devon
    Default creamy residue on oil filler cap and neck
    I was going to post a new thread as I have noticed this recently. I've only had the car a couple of weeks and noticed the creamy sludge on the oil filler cap and thought that the head gasket might be going. The dipstick is clean as are the cams that I can see, and there is no sign of oil contamination in the water. The garage did a service and said that it was probably condensation (made worse by short journeys) and not to worry about it. I have since covered another 700 miles and the scum has returned. Glad I found this thread. I can relax now.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
