Results 1 to 3 of 3
Thread: Amp Leakage from battery?
    Jun 2007
    Kilmarnock
    Default Amp Leakage from battery?
    Hi all,
    GSI not driven for 6 days and went to run it yesterday to find a flat bettery. Just the relay clicking sound but no turnover.
    Jump started it and went for a 10 min run and all OK. Voltmeter across vattery shows 12.44V and when revved up to 14V so i assume the alternator is OK.
    Did a quick check with ammeter and there seems to be a 4 amp leakage across the earth terminal.
    Pulled a few fuses and the rear brake light fuse showed a drop when removed. Brake lights work fine though.
    Is there anything else i can do to trace the leakage? ( Am i even checking it right??)
    Thanks for any advice.
    RoddyKFC
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    think you need to check the car when its locked up. leave it for a few minutes with the meter connected inline with it so the modules all go to sleep. Could be a matter of tracing through and unplugging modules and retesting to see which one is pulling the current whilst its supposed to be asleep.. I have heard of the REC causing a problem of this on Astra's.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by RoddyKFC View Post
    in that case it might be worth a quick check on the condition / tightness of the earth connections on the rear lights aswell
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Oil leakage 1.9 CDTI 110 kW
    By Longdude in forum Engine & Drivetrain
    Last Post: 24th April 2012, 21:01
  3. Power steering rack leakage
    By Luke52 in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2009, 00:32
  4. Water leakage on GSI 3.2V6
    By RoddyKFC in forum Engine & Drivetrain
    Last Post: 28th August 2007, 23:40
  5. When I was checking for oil leakage...
    By haegwani in forum Engine & Drivetrain
    Last Post: 21st May 2007, 21:52
