Results 1 to 3 of 3
Thread: Internal Pull Handle Removal Help!
    Regular Member aaruck's Avatar
    Cheshire
    Vehicle : Insignia
    Default Internal Pull Handle Removal Help!
    Can anyone tell me how to remove the cover from the pull handles on the front doors? The coating has started to come off and I think they would look tidier if I just removed the coating. I cannot get them off though. They appear to be stuff near the top and I dont want to pull too hard incase they break.
    Is there a trick to this?
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    yes, they are a push clip fit only.. I normally go either from half way up and get my finger nails under it, or you can gently get something underneath the bottom of it to help it on its way. Where you think they are stuck are merely little bits where they extend into the door card, Normally if you arch it a bit from the middle it helps them come out
    Exactly They just prise off.
  1. Internal door handle panel removal instructions
    By msqualo in forum Bodywork & Interior
    Last Post: 24th February 2012, 16:47
  2. removal of handle covers
    By hairy31 in forum Styling
    Last Post: 6th October 2010, 20:28
  3. door handle removal?
    By ronnie63 in forum Bodywork & Interior
    Last Post: 11th June 2009, 19:03
  4. Vectra Estate Tailgate Interior Pull Handle
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 14:59
