Thread: Reverse light switch Signum 2.0T
    Stockholm
    confused Reverse light switch Signum 2.0T
    The reverse lights doesn't come on when I put in the reverse gear. I have checked the bulbs, but both are OK. The light on the dashboard indicating a broken bulb is on, but they all seem to be fine. I suspect the switch that makes them come on. Problem is, where is it and how does it look? If it needs to be replaced, what is the part number?
    Northampton, UK
    Quote Originally Posted by olajon View Post
    Have you checked that the wiring in the boot is intact?
    Northampton, UK
    If you look at the "How2" for parking sensors, it shows the wires for the reverse light -
    http://www.vectra-c.com/forum/showthread.php?t=11893
    Might be an idea to see if the fuse has gone, if there's any power going through the wire or if its come loose.
    Maida Vale
    From my experience with several other cars, the reversing light switch is likely to be screwed into the gearbox casing somewhere...on some cars you reach down through the engine bay, on others its accessed from under the car.
  1. Signum reverse switch cabling?
    By mudcow007 in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 14:14
  2. Reverse light switch
    By wiganrl in forum Troubleshooting
    Last Post: 4th February 2011, 21:26
  3. is this were reverse light switch is supposed to be?
    Last Post: 4th February 2011, 13:49
  4. where is the reverse light switch on vectra 52 reg
    Last Post: 8th December 2010, 20:19
Tags for this Thread
