Thread: 1.9 cdti 120bhp, cooked !!!
    scotland
    Default 1.9 cdti 120bhp, cooked !!!
    signum cdti 120 (54 plate, 41k miles !!)
    Driving home yesterday when the coolant level low indicator flashed up on the dashboard ... stopped and checked the level..fine..carried on down the road, then it flashed up again, so i pulled into a garage. Checked the coolant level again...everything seemed fine.
    10 min down the road...there was a squeeking/hissing noise (the noise increased/decreased with engine speed) from the engine, then she overheated, red light came on, so i instantly pulled over and switched off.
    Smoke was coming from the left side of the bay, with a strong smell of burning.
    Any suggestions guy ? Im thinking water pump ???
    cheers
    steve
    Wales
    sounds like coolant system has sprung a leak somewhere - you can often find coolant residue (white?) sprayed out from the leak.
    scotland
    got the timing belt cover off today !!!!
    Cam Belt is blistered, right plastic pulley is almost burnt away.
    Cant actually turn the engine over by hand which is very worrying.
    I think maybe its because the belt has melted onto the plastic pulley, and water pump pulley....fingered crossed.
    Im going to cut the belt off tomorrow ...... 40k miles on this car !!!!!!!!!!
    Regular Member foyboy241177's Avatar
    May 2008
    eastbourne
    have had several cars througe our vxh garage the problem is the water pump siezes and makes the belt get vvv hot as not free to move cam belt kit and water pump will cure fault
    scotland
    This seems to be a common problem.
    Has anybody had any luck claiming from Vauxhall ?? or insurance ??
    scotland
    belt, tensioner, guide and water pump replaced.
    Problem solved
  1. Help Please - Signum 1.9 cdti 120bhp
    By T111mts in forum Vectra C / Signum Troubleshooting
    Last Post: 17th February 2013, 19:10
  2. 1.9 CDTI 120bhp
    By loopy_kiwi in forum Diesel Engine related
    Last Post: 13th April 2012, 19:33
  3. Changing a 1.9 CDTi (120bhp) EGR?
    By lee gsi in forum Engine & Drivetrain
    Last Post: 23rd February 2011, 15:54
  4. 1.9 CDTI 120bhp Hesitating
    By cphaza in forum Engine & Drivetrain
    Last Post: 4th October 2010, 22:54
  5. CDti 150/120bhp tuning box
    By sthomson1 in forum Parts for sale
    Last Post: 22nd April 2009, 21:39
