Results 1 to 10 of 13
Thread: Well i did try to de-fog the headlights....
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Well i did try to de-fog the headlights....
    after reading some threads on here about how different members de-fogged their pre facelifts horrible foggy headlights i thought i would give it a go as quiet at work on saturday afty, so got the car in the workshop,popped the bonnet,took the 2 rear covers off the back of each light,stuck 2 sheets of a4 over each lense turn the lights on (full beam included)and heated with large blow heaters for over 2hrs! now after this amount of time all the condensation had gone from both lights so i left 4 hrs to cool down(back to garage temperature) then put 1 of those silica gel packs in each headlight,then rear covers back on. just been out with the dog before work (5.30am!!) and the 4king lights are fogged up to **** again,any ideas if i did anything wrong in the above method? sorry about camera phone pics.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    anybody or is it gonig to be operation headlight hunt?
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    There must be a slight leak allowing air in somewhere. id remove light and silicone seal alot of the areas which look like the might let air in
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by Gregg View Post
    do you think though there would be a leak on both lights?
    Northampton, UK
    I find that when I "push" the plastic lens in on my drivers headlamp, its soft and I get a "woosh" sound, like air being sucked in / pushed out. I dont get this on the passenger's side, it feels firmer. I only have a moisture problem with my drivers side and think I need to replace it now.
    Aug 2007
    Great Wyrley
    Quote Originally Posted by bobby-tupper View Post
    I am not sure i dont experience the problem, however condensation is a result of moisture which is found in air, if you have treated it already then i would imagine there is a leak somewhere it may only be a pin hole but it will let air in and moisture
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by n_hudson View Post
    looks like your going to have to put your old front end back on
    Last edited by bobby-tupper; 22nd February 2009 at 10:35. Reason: rush typing im at work
    Northampton, UK
    looks like your going to have to out your old front end back on
    I might do after the GF hit hit the other day!
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    hope she made it up to you mate
    Northampton, UK
    Not yet, Its not too bad, just need to align my panels/bumper again, got a few cm's gap and the bonnet is a little bent on the corner. Just need to find out how to do it LOL. I had help last time! The dozy cow reversed into, (Didnt see it apparently) then thought she was not giving it enough power as it was up hill, what she was doing was PUSHING into my car! ARGGHHHH! I know I need a new headlamp anyway as a lug broke on top.
  1. LHD / RHD Headlights
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 19:46
  2. headlights
    By SimonL in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 12:50
  3. headlights dim
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 16:26
  4. SRi Headlights
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th October 2008, 09:11
  5. Headlights
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 17:55
