Thread: warning lights
    lancashire
    Smile warning lights
    hiya guys,im new to this,so hello.just wondering,ive got a amber warning light on the dash were the rev monitor is,it looks like a brake warning light,which seemed favourite seeing that the front pads were low,so ive had her serviced an new pads but the light is still on. the fluid level is fine,an rear brakes are fine.but still the light, its a 54 cdti sri, help!!!!!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Sounds like the brake pad wear indicator/wire/loom fitted to one of the front n/s pads.
    Was it replaced when the new pads were fitted? It needs to be replaced if the brake pad warning light came on as it's designed to make contact with the disc when the pads wear down to a few mm. Ask the garage if they put a new one on.
    They could have re-fitted the old one (naughty), the old or new one could have a broken wire (two wires to the sensor part that's fitted in the pad) or could just be a bad connection where the 12-18" loom connects to another wiring harness, located just behind the n/s suspension strut. Trace the cable back from the pad to find the connector.
    HTH
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    lancashire
    thanks alot guys.il check it out
    Regular Member MACVECT's Avatar
    Cheshire
    If they are fitted, check the wires to the rear pads also. They could be broken and earthing out. Just a thought.
  1. warning lights
    By ian 1234 in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 13:49
  2. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  3. warning lights
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2011, 17:09
  4. warning lights
    By lee_car in forum Vectra C / Signum Troubleshooting
    Last Post: 30th October 2008, 14:01
  5. warning lights
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2008, 21:20
