Thread: Swirl valve motor
    Glasgow
    Default Swirl valve motor
    I've just finished fixing my swirl valves, or rather the motor. I bought a new motor and changed it over, i've attached a couple of pics where you can see the little plastic rod and ball joint had become detached from the motor arm probably because the little ball joint was very stiff in the socket. The motor is working perfectly but just not attached to anything so as far as the ECU is concerned everything is fine and shows no faults. I felt the car was down on power with a flat spot at 1800rpm, now the flat spot has gone and the car feels much more grunty. The whole job took about 3 hours.
    Attachment 16615
    Attachment 16616
    Looks like the weld broke? Nice diy repair though
    Must be a poky motor to strip the fitting.
    Kingston Upon Hull
    Can you please tell me where the swirl valve motor is on the engine
    A mate of mine is having problems with his car soon as the engine gets to 2000rpm it looses all power [ in all gears ] he has changed the egr twice and i was wondering it the swirl valve could be the problem.
    his car is a 2l diesel c vectra
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by jacko52 View Post
    Don't think there is one on the 2.0 oil burner matemate.
  1. swirl valve rod
    By pha-q2 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2012, 17:36
  2. Egr valve, swirl valve problems etc..
  3. Swirl Valve Again!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 23:37
  4. swirl valve
    By d2sds in forum Petrol Engine related
    Last Post: 5th December 2007, 21:42
