Results 1 to 10 of 13
Thread: headlight washers.
    Regular Member Netstar's Avatar
    Jan 2006
    South Wales
    Default headlight washers.
    Hey guys,
    Noticed yesterday that my headlight washers were no longer popping out and spraying.
    I know your lights have to be on for this, so its not that.
    I cant remember the last time i actually saw the spray coming up from them last to be honest, but it awsnt long ago.
    My though are somehting to do with the heavy frosts we've had.
    I leave for work in the dark and maybe they were frosted/frozen shut and the motor has gone caput?
    Any ideas anyone?
    Surrey
    Pump blocked.
    Jan 2006
    South Wales
    They dont even pop out though. Would a blocked pump cause that?
    Surrey
    I am sure it's water pressure that lifts them up.
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    The water pressure pops them out. My bet is on the pump too.
    Jan 2006
    South Wales
    right. ok. I'll have al look into it. Would they have a seperate pump? As the normal washers still work.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    i had this in mine mate, turned out to be the pipes going to the washer jets had blocked up with green algy type crap and yes the jets work off the pressure from the pump
    Jan 2006
    South Wales
    Cheers chaps.
    I assume its a bumper off job then?
    Surrey
    Remove the bottle and give it a clean.
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    right. ok. I'll have al look into it. Would they have a separate pump? As the normal washers still work.
    I know on my pre face-lift with xenon's, the headlight washers run off a separate pump so would imagine its the same for yours. They're situated next to each other on the washer fluid reservoir.
  1. Headlight washers
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2011, 08:25
  2. headlight washers??
    By vauxhall-john in forum Bodywork & Interior
    Last Post: 4th January 2011, 13:21
  3. Headlight washers
    By rockh in forum Styling
    Last Post: 30th July 2009, 22:14
