Results 1 to 3 of 3
Thread: CD70 and Bluetooth Phone Help !
    Sofia
    confused CD70 and Bluetooth Phone Help !
    Hi Folks,
    Iíve just buy Vectra C (2005) with CD70 integrated and I want to connect my Nokia E71 phone to the car via Bluetooth. Can someone help me for these questions:
    1. As this is secondhand car Iím not sure do I already have a BT module installed. So how can I check that and how is the process of pairing the devices is going on. Someone have tutorial?
    2. Iíve check with all Opel dealers here in Bulgaria for this module and no one from them imports the BT module so if anyone can tell me the exact model/version, part number and a online store where I can order the BT module?
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    If your car has BT installed it'll show another tab with a phone on the centre display, My display has 4 tabs, audio, phone, Nav and BC. I dont think the Nokia E series works with the Vauxhall / Opel BT though thanks to Nokia wanting to sell its own car kits rather than support those factory fiited by GM and quite a few other car companies... you may be better off buying another phone if you have factory fitted BT installed in your car, if you dont have factory fitted BT installed then you'd be better off buying a Parrot BT kit if it works with your phone...
    Before you buy the BT module (which will no doubt be expensive) check to see if your phone works with the GM BT kit, a lot of the N & E series Nokia's don't work with the GM BT..
    Sofia
    Thanks a lot Pete. As I have only 3 tabs without phone this means I donít have BT module installed L
    Regarding the phone compatibility Iím not worried as Iím changing my phone on yearly bases. Also as I understood the only problem is phonebook. Regarding the Parrot BT kit I need to install another display but I want to have everything on one display managing from the wheel J. Can someone give me a clue for the cost of the Opel BT module in your country as no one imports this here in Bulgaria and Iím often visiting London? Also can someone recommend a Parrot BT kit model?
  1. CD70 Bluetooth/Phone Flashing "Phone Safe"
    By mgsc00840 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 08:15
  2. CD70 Bluetooth/Phone Flashing "Phone Safe"
    Last Post: 14th November 2011, 23:13
  3. Bluetooth Phone Kit
    By KeefyJ in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2008, 17:46
  4. CD70 Bluetooth Phone list
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2008, 20:58
