Thread: right, need some advice.
    Regular Member cdms811's Avatar
    Newcastle
    Default right, need some advice.
    got towed by the aa last week, long story short fault codes p0301 & p0302 cylinder 1 & 2 misfire. aa diagnose as coil pack. went to dealer order part and it finally comes today. fitted, no differenc. thank you aa am now £70 down and no closer to finding what is wrong
    now the advice. what could be causing a misfire on more than one cylinders? had emissions light on so looks like some unburnt mixturein the system
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Spark Plugs?? Maybe Injectors??
    Full Member
    Bristol
    It can't be spark plugs comuters can't detect them And he is showing a code. It has to be injectors or a wiring fault. The only way to eliminate is to take injectors out of 3 4 if poss and swap around.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i would get the AA to come back out and tell them that they had diagnosed the fault wrongly, tell them in no uncertain term's you aint happy and you want it sorting.....
    Midlands Mod Shop - NFFC.
    Newcastle
    injectors? expensive?
    north yorkshire
    is your engine the z22yh ? if so you may have a high pressure fuel pump problem. i have had this fault before, although there is usually trouble p1191 fuel rail presure sensor stored aswel, but not always. you will be able to see within the data list on tech 2( if you know anyone with one!) a faulty fuel pump is quite easy to detect on the data list!
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    could be a head gasket problem as if the gasket is gone between the 2 cylinders,as to the coil pack if this does go down it will cause a misfire in cylinders 1 and 4,2 and 3,never 1 and 2 or 2 and 4 ,what you need to do is get a compression check done
    Newcastle
    Now looking like it may be the Fuel pump, really starting to hate this car
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
