Thread: Rare accidential kicks with the 5 speed auto gearbox
    Sofia, Bulgaria
    Default Rare accidential kicks with the 5 speed auto gearbox
    Hi there!
    I am experiencing some strange kicks with my automatic gearbox on my Vectra C 2.2 DTI.
    One thing is when breaking - sometimes it goes down to 2nd and 1st not very gently.
    The other case is when driving with no acceleration, breaking slightly for a turn and then getting a pretty sensible punch when pulling out.
    Both of them occur rarely but still is it normal?
    I just got my gearbox fully rebuilt after it drowned... and it works pretty good so far (about 250 miles).
    I know some of you have similar experience. Please share it.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Check the fluid level. Incorrect levels can cause what you've described.
    Jul 2006
    Mexico
    Mine does little "kick" when the gears are cold....when braking ....I got used to it but I agree with GTR first check the oil and start from there.
    Maybe a software update may help too.
    HTH
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    First thing we did was a software update. As that didn't help we changed the gearbox oil...
    After about 3000km the car was undrivable. Rough changes made it horrible to drive...
    Got a factory rebuilt autobox from Japan. Under warranty obviously
    Sofia, Bulgaria
    Thanks for the suggestions!
    The box is practically as good as new and the oil level should be fine too as the service which repaired it knows how to do it (mine was not the first one with this problem).
    The newest software was uploaded even before the rebuilt so this shouldn't be the issue.
    I think that at some moments the gearbox can't match to switch the gear quickly enough and this causes the jerking.
    Again this happens very rarely and in total the gear switing is just fine upwards and downwards. I was just curious if someone observed similar tougher accidential switches.
    Looks like all in all this (AF 33) in general is a gearbox which is not really fine...
    Sofia, Bulgaria
    Default Back to the subject
    So here is the rest of the story. After my complaints the control unit - the so called "brain" (don't know the proper term in English, sorry) was sent to a hydraulic stand and adjusted. Now the gear change is much smoother and works fine but the problem stays - when I brake harder then usual and release the brake pedal at low speed (idling let's say at 10-20 mph) I get a sharp gear change into 2nd and 1st (depends on the speed).
    So has anyone of you experienced something similar? Maybe it's some safety system engaging thinking that it's an emergency brake? Any suggestions?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by slavi View Post
    a - change the gearbox oil
    b - check if there is any coolant loss as it may go into the gearbox, slowly wrecking it!
    c - good luck mate
  1. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  2. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
