Results 1 to 10 of 14
Thread: anyone with any ideas
    norfolk
    confused anyone with any ideas
    has anyone had the same problems i have at the moment with my 2002 sri??
    indicators do not work properly one flash only
    wipers do not work properly one wipe only
    speedo and rev needles dancing up and down
    hand brake,battery and abs warning lights flashes on
    fuel and temp gauges switch on and off
    dash warning alarm goes off for no reason
    interior light flashes on and off
    centre info display cuts out
    radio cuts out
    radio remote control lights flash
    rear window demister cuts out
    heater fans cuts out
    sometimes immobiliser "padlock" warning comes up so i have to disconnect battery to clear this so i can start car again.
    these faults do eventually stop for a while
    basically the only thing that does work with no problems is the engine !
    i think it could be the sim but dealer thinks overwise
    anyone with any ideas???
    Ashington, Northumberland
    CIM module mate. Common fault
    Sunny Dartmoor
    I would've said the CIM,what does the dealer say?
    norfolk
    hi dealer says possibly faulty wiring ive checked wiring, fuses and relays charge voltage but ive found nothing obvious .
    I'll lay money on it being the CIM
    norfolk
    hi i did suggest to dealer it could be the cim module they have quoted me 405 inc vat for a replacement does that sound reasonable ?
    Regular Member ballogie's Avatar
    Scotland
    Quote Originally Posted by johnrolfe View Post
    deffo cim, i had all the symptoms you describe
    fixed under warranty - is this an option for you?
    north yorkshire
    9 times out of 10 this will be the c.i.m. ive changed hundreds at work very common fault. £405 sounds about right!
    Full Member Big Sig's Avatar
    Check the ABS plug too
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Bang on. I cured my problems with some WD40 on the plug, although there is a proper fix. You have nothing to lose. Some of the systems you mention aren't controlled by the CIM though, but I may be wrong.
  1. Anyone got any ideas
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2011, 16:42
  2. Ideas Please
    By Tomb in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 16:21
  3. Any Ideas ???????
    By johnnyd2003 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:13
  4. Any ideas as to what this is
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2008, 21:21
  5. Any Ideas?
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 16:49
