Thread: what a clown!!!
    Regular Member WKD-mcc's Avatar
    glenrothes
    Thumbs down what a clown!!!
    hey folks,well,for a little while my rear pads have been grinding like mad,really really bad.so me thinkin,the last two cars i've had i changed the discs and pads myself no problem.so gives it a try,first problem my rewinder was to big by a few mm's.so I tried something else,got it rewindin but it wasnt going nowhere so took the caliper right off,by disconnecting the brake hose stupid thing to do now,rewound it and the fluid started coming out,knowing that i'l have to put somemore brake fluid in i just put the new pads in and put the caliper back on.but the disc,i couldnt get that off ass the nuts at the back where on far too tight for me to get them off as i just had the car up on axel stands .feel like a complete plonker cos i've gone and mucked it up thinkin i knew what i was doing.sorry folks if you'l think am daft but you learn by your mistakes.cars out of use till the problems resolved for now though,am not stupid enough to go out and about in it just yet .owell theres my stupidity for the day people.think this is what i'l be needing
    Ops, you're not the first m8 hope you get sorted over the weekend. ..
    Regular Member leonvectrac's Avatar
    south shields
    at least you tried
    glenrothes
    never thought it would go so badly but awell,always tomorrow for attempt number two eh,hopefully it doesnt have to end up like this cos am proper skint
    Jun 2007
    Black Country
    dont remove the bolts mate
    just remove the grub screw that holds the rear disc on and the disc will slide out of the caliper opening
    bit fiddly but works a treat
    bleeding the brakes, your on your own mate
    glenrothes
    tried by takin the grub screw out,tried twistin the disc,turning it,tilting it.wasnt happening.whats required for bleeding it then,geuss thats what al be doing tomorrow then nice
    Regular Member ballan22direct's Avatar
    isle of lewis
    get yourself an easybleed! connects to fluid resevoir and tyre valve pumps the fluid through so you just have to open an close the bleed valve.
    glenrothes
    Quote Originally Posted by ballan22direct View Post
    thanks for that,where about can you find one of them,actually looked at a couple of bleedin kits in halfords the day.must of psychically knew something was goin to go wrong hmmm.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    or just do them the old fashioned way.
    glenrothes
    well...out first thing this morning near enough.need the car takin in to get the discs off because the nuts on the bracket for the caliper is far too tight for taking off on axel stands,so just changed over the pads and left the old discs......so more pads next time round then no doubt.but even better,went and got the EEZI bleed kit from halfords at a think was £16.49 if i remember right and what can i say.for a novice like myself that was pretty damn EEZI so if anyone else does it and doesnt want to do it 'the old fashioned way' then thats the way to go thanks ballan22direct.good advice on that anyway
  1. Ebay clown....
    By Dose in forum General Chat
    Last Post: 13th September 2008, 20:01
  2. 2 jam sarnies and a clown
    By leroy in forum General Chat
    Last Post: 13th March 2006, 09:51
