Thread: consendation in headlights
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Default consendation in headlights
    my n/s headlight had very bad consendation,the car only just scraped the mot with the headlight beam,today i decided to take the headlight off to fix the problem,(and clean the washer bottle as well) anyway there was a lot of water in the bottom causing the consendation,so i have drilled a small hole at the lowest point in the headlight so hopefully any water in the headlight will drain away,i have to fix the headlight leveling as well as it was not doing a lot,i found some dirt and a little corrosion on one of the pins,probably caused by the consendation so im hoping that this cures that as well
    Good luck with that mate. Do you think it has anything to do with being a plastic unit as apposed to glass as I have never seen this mentioned as a possible cause? .
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by Tadpole View Post
    my be partly my fault as when i fitted my hid bulbs i made the hole in the rubber cap slightly too big,plus the windscreen wash filler is just above it as well
    Regular Member hibbsy18's Avatar
    May 2008
    Cambridgeshire
    best way to get rid of that is to remove the entire headlight. take off the covers and leave it on top of your engine. when its hot obviously
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by hibbsy18 View Post
    i managed to get rid of it by leaving the headlight over a heater (it is one of those frost prorect heater with no fan),i did drain a lot of water out of it which did not help,i have had to order a new headlight anyway as the motor does not work and there is corrosion in the plug
  1. L@@k what I've done with my headlights !!
    By Lakom_2006 in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2012, 07:43
  2. LHD / RHD Headlights
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 19:46
  3. headlights
    By vec-cal in forum Styling
    Last Post: 27th December 2010, 17:46
  4. headlights dim
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 16:26
  5. Headlights
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 17:55
