Results 1 to 10 of 11
Thread: Is the Vec C suspension setup at the front same as a Vec B?
    VIP-Member MCD's Avatar
    NE Manchester
    28 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default Is the Vec C suspension setup at the front same as a Vec B?
    My Eibachs have arrived!
    Going home to fit them in the next hour! Ive lower loads of Vectra Bs, i was hoping that the C is going to be the same?
    Ive heard they are different at the rear? Possibly easier than a Vectra B? But are they the same up front?
    Is there anything i need to know or watch out for different to the B?
    Cheers guys!
    Excited to get her down a bit now, and get rid of these crap springs the MOT place fitted!
    Mike
    Merseyside
    This is of interest to me too!
    Full Member Big Sig's Avatar
    The rear is easy, the dampers can be done without removing the rear wheels! Spring compressors are needed though
    I would have thought the fronts would be basically the same - ball joints, springs etc
    NE Manchester
    28 Post(s)
    Engine : z20net
    Mileage : 80k
    Ugrh! Hope there isnt any ball joints to do.... i hate em!
    On the B,
    1. disconnect drop link.
    2. two nuts on bottom of shock.
    3. Nut in strut top in engine bay.
    4. Shock out
    5. Spring clamps on etc.. do the business.
    The rear you had to remove the whole arch liner, shocker everything! ****ty job really! Sounds like the rears are much easier now..
    Mike
    There may not be, it was just a guess that there would be.
    Regular Member blue estate's Avatar
    oh well.. I tried..
    fronts are tha same Mike, been there and done it
    oh well.. I tried..
    Only thing i found easier to do on the C is to crack the top nut loose on the top of the shock before taking the leg out
    Merseyside
    Is there a How 2 for shock/spring changes on the Signum??
    NE Manchester
    28 Post(s)
    Engine : z20net
    Mileage : 80k
    Quote Originally Posted by blue estate View Post
    Cheers, yeh i normally do that on the deck anyway.... They should come appart OK! It was MOT'd the week before i got it, and had a cracked spring so they put new springs in... god nows whats in it... but its sat higher than an LS, let alone a SRi!
    How many bolts on the rear? Just the shocker.. then leg down and spring out??
    Mike
    oh well.. I tried..
    One bolt at the end of the trailing arm, through the bush, then swing it down, takes some force to hold down, lift spring out... fitting is the reverse of removal
  1. For Sale: lowered sports suspension setup
    By andy.l in forum Parts for sale
    Last Post: 30th November 2012, 18:20
  2. Suspension setup advise.
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2010, 09:58
  3. Suspension Setup
    By paulhb in forum Handling & Braking
    Last Post: 18th January 2009, 17:03
  4. SRi Complete Suspension Setup
    By The Doc in forum Parts for sale
    Last Post: 30th March 2006, 14:35
is vectra c same suspension as vectra b
