Results 1 to 10 of 14
Thread: Tech2 unit, aka ODB2
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Default Tech2 unit, aka ODB2
    Evening guys/girls. Been doing some digging on this tech2 unit and i appear to be able to get the connector lead/software package to be able to read/reset fault codes plus the other stuff Vx garages can do. Any advices on this before i pay £180 for the packages.
    May be of benefit to others if we have a group unit
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Ordered this unit now. Heres the link for it http://www.onboarddiagnostics.co.uk/...art/Itemid,39/
    Gonna use this to clear and check my fault codes. So if anyones near me and needs to check fault codes they'll be more than welcome to come here and check them. Although i recommend VX for stuff still under warranty.
    I overfuelled my poor ole car with the CR2 and its got a fault logged now which is why i'm buying it. to clear and also cause i like gadgets to play. Bet AJA's ear pick up a bit now
    OOHH...
    Can you write to the car with it or is it read only..Been looking at CAN enabled packages to run from the laptop..Need to change my scanner by a new one and the CAN module is too much for the use it'll get put to..
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    If u can erase the fault codes i'd safely say u can write to it.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Reset is different to writing to the ECU map if that is what you mean.
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    u could be right. Writing to the ECU map would scare me, I'd be happy to just reset fault codes. Gonna have another look at the webpage.
    'Norf Yorks.
    ECU map is kept on one chip if you see what I mean, and is highly encrypted. Though obviously not invincible!
    Reset codes are elsewhere if you see what mean.
    Can't explain very well, wine talking tonight at the mo.
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Carling black label talking here Yeah i can. Another area of the ECU which is write protected/encrypted as u say. I can see how it can work. I think i vaguely recall something about a proper setup costing about £2500 or so to be able to write to the ECUs properly.
    Yeah.. that's what the spend was going to have to be..
    I think i'll keep looking into laptop based systems for now..
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    What you looking to do with full access to the ECU map? bit of home tweeking?
  1. Tech2 unit CHEAP
    Last Post: 12th January 2013, 08:08
  2. Santa Brought me a ODB2 code reader.
    By vmb2722 in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 31st December 2012, 19:03
  3. ODB2 communication error
    By wayne1000 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th January 2012, 16:33
  4. ODB2 Codes P0614 P0616
    By duncmill in forum Engine & Drivetrain
    Last Post: 21st October 2009, 13:23
  5. Tech2 DIY Unit
    By the-ferret in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2008, 19:00
