Thread: Intermittent spanner light
    Cheshire
    Angry Intermittent spanner light
    Hi,
    Has anyone got any suggestions as to what to check on my signum for the following fault(s)
    The spanner light comes on intermittently with two possible results:
    1) Light stays on for maybe 10 seconds then goes out of it's own accord, no obvious effect on performance.
    2) Light comes on, then, engine rpm very slowly drops to 500rpm, accelerator has no effect at all. To reset I have to switch off for at least 10 seconds.
    The fault only appears with the engine well warmed up and running for at least 30 minutes at normal road speeds. If the weather is cold (below 6C) it doesn't seem to happen at all but above this the car will run normally for a good while but once it's started this fault it becomes more and more of a problem. Last weekend for example; Friday, drove from cheshire to London, one stop at Watford Gap, no problem at all. Sunday, returned from London, the car was fine until the M42 then it started playing up. I eventually got to the services on the M6T after having had to use the hard shoulder 4 times. Stopped for about an hour, the rest of the run to Cheshire (Jnc 16) no problem.
    Poxhall don't seem to have a clue, because it's intermittent and not being logged they can't fault it. I've checked all the hoses, joints, electrical coneections. Can't find a problem but there obviously is one.
    Can anyone help please
    May 2008
    Derbyshire (south)
    Few more details may be good mate, ie, is it petrol or diesel, has it had an induction kit etc, or a re-chip?? Year mileage, all this would help you on your mission??
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    With it only working when the engine is hot it could be your vacuum unit , also where are your actuattors situated if you have two on your bulkhead and one by your maf unit you could be ok , but some early dti,s had them sited inbetween engine and battery and these should have been retrofitted to be by the maf these were found to be over heating and failing .
    and still loving it
    Cheshire
    Quote Originally Posted by mitch1965 View Post
    oops sorry, it's a 2.2 diesel, 53 plate 90k. Last service it had a software update to the ecu
    Jul 2006
    Mexico
    Sounds like a bad sensor some where, but the only way to point the right direction is getting the codes read IMO.
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    mine did this for a few days during the cold snap.
    i also 'forced' it to do it the other day by making the car 'jump' in first gear by feathering the accelerator.
  1. Intermittent spanner light 2.0 t
    By roverjay in forum Engine & Drivetrain
    Last Post: 13th January 2016, 08:47
  2. intermittent spanner light
    By dervb in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 26th June 2012, 02:01
  3. intermittent spanner light
    By dervb in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 23:10
  4. Help intermittent spanner light
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 21:20
  5. Juddering and intermittent spanner light
    By matth42 in forum Troubleshooting
    Last Post: 20th April 2008, 01:53
