Thread: grinding rear brake
    herts
    Default grinding rear brake
    When my rear brakes started to grind i thought simple job ha.
    when checking them only passenger rear side was grinding, but both rear pads have enough pad on the shoe. and the disc on the offending wheel has a slight grove right in the middle of the disc so my question's are;
    1) could it just be something lodged in the pad
    2)will i need to change the disc now it has a slight grove in the middle
    3) how easy is it to change them
    cheers guys been driving my mates old vw transporter van around doing my head in
    Full Member spennny's Avatar
    Blantyre
    Hello Mate,
    You answered your own query :-)
    Q1 ) Could be, sounds like a small stone
    Q2 ) If there is a slight groove , there is def something stuck in there wearing it away
    Q3 ) Easy to do mate, get yourself a rewind tool though to be on the safe side, and make sure it fits vauxhalls
    herts
    lovely mate will do...whats a rewind tool and do i need it? heard of putting a air hose around the pad anyway thank for advice
    Blantyre
    Quote Originally Posted by langers306 View Post
    The rewind tool will slowly rewind the piston back into the caliper for you, a few members have taken the chance and pushed it back in as you do with the fronts, although not advisable (i wouldnt do it)
    HAve a look here mate, give you some better info
    Link HERE
    herts
    spennny you a legend good link and easy to follow pics will post out come
    He's been called lots of things but never a legend until now.
    Blantyre
    Quote Originally Posted by Tadpole View Post
    Your just jealous
    Maida Vale
    Quote Originally Posted by spennny View Post
    Link HERE
    I don't think anyone's just pushed the piston back in, as it's threaded. What you mean is some people have used something other than a rewind tool to turn and retract the piston, i.e. a pair of long-nosed pliers, where the nose fits in the two holes in the face of the piston.
    Blantyre
    Quote Originally Posted by Thomas1 View Post
    Yep thats what i meant...... see you knew what i meant
    herts
    i'm gone if i have to take the mrs to work in the back of the van anymore she's off me thinks. only two spaces in the front..... and the dog's got the other
  1. Grinding noise from the rear breaks
    By freddy in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2011, 18:07
  2. hard, grinding, weird brake pedal
    By TimTay in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2011, 22:44
  3. brake grinding noise
    By li4m in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 20:54
  4. signum..grinding noise from rear
    By uaintsinme..right in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2009, 21:47
  5. Grinding rear brakes
    By shillbag in forum Suspension, Wheels & Brakes
    Last Post: 3rd June 2007, 11:34
vectra c rear brake grinding
Tags for this Thread
