Thread: mot time
    Regular Member 06 vectra's Avatar
    Jan 2008
    meigle
    Default mot time
    ok got the mot coming up in the next two weeks so what do i need to check to make sure it wil pass first mot so be gentle first mot fot the car aswell many thanks ahead of advice
    Ashington, Northumberland
    Just make sure the basic stuff is ok mate, like your lights (reversing lights aren't testable, neither is the n/s fog light). Check your tyres are up to scratch (1.6mm and free of deep cuts etc). Are your pads and discs ok (pads not below 1mm and discs not excessively pitted and worn). Make sure the car isn't minging either because if the tester can't see components for muck, he may refuse to test it. There will be a lot you can't check yourself but you can make things easy for yourself by at least checking the things you can see. HTH mate
    Jan 2008
    meigle
    how worn would you say a disc would be for a fail as mine have a fair groove round the outside of them or would it be advisable to change them anyway
    May 2008
    Tyneside
    In my experience as long as the brakes pass the efficiency test thats OK. I have had advisories for disc wear and corrosion but no fail. I have done jobs in preparation for MOTs which on reflection I wonder if they actually needed doing or just me being fussy. Best check the basics and wait for the test result. HTH
    Quote Originally Posted by 06 vectra View Post
    You should be ok, they have to be pretty bad to fail
    Quote Originally Posted by tridley View Post
    In my experience as long as the brakes pass the efficiency test thats OK. .....
    That is not always the case. You could have brilliant brake efficiency, but if I decide that a disc(s) are excessively pitted, I will fail it, because it says in the testers manual that excessive pitting is a reason for rejection, not because I am a barsteward lol
  1. For once in a long time both cars are clean at the same time!!!
    By ijk571 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 10:40
  2. Long Time Looker, First Time Poster......
    By Whisky in forum Introduce yourself.
    Last Post: 26th March 2011, 22:37
  3. Long time looker first time poster
    By robg8070 in forum Introduce yourself.
    Last Post: 6th December 2009, 11:51
  4. long time user saying hello for first time!
    By Karnah in forum Introduce yourself.
    Last Post: 10th August 2008, 22:07
  5. Long time lurker, First time poster!
    By Crumpster in forum Introduce yourself.
    Last Post: 22nd October 2006, 07:47
