Results 1 to 10 of 14
Thread: Help!! how do i change the rear tailgate breaklight?
    Northampton
    Exclamation Help!! how do i change the rear tailgate breaklight?
    i bought a new rear tailgate breaklight but i dont know how to fit it as i did open up the panel but it was hidden away. is it a direct replacement from the outside?
    Northampton
    do i just ave 2 rip it out?
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    I take it that you mean the 3rd Brake light, the one in the top centre of the hatch itself?
    Northampton
    yeh sorry yeh 3rd brake light
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    You have to get to it from the back to remove it.
    It means taking off the 2 rear window side trims, then remove the 4 studs from the lower edge of the trim panel. then undo the retaining screws in the centre of the panel and pull out hte centre pins of the rivets.
    Then gently pull the panel away to release the remaining clips.
    You then see the back of the brake light. A couple of inchs away from either end of the lamp is a locking clip. You have to squeeze each one in turn whilst at the same time pushing in the lug at each end.
    You can then pull out the light.
    HTH
    Northampton
    ohh rite kinda a long process then.. i shall try it out 2moro and will let u no how it goes.
    im goin vaux 2moro and no the guys there see if they are willing to help me out
    cambs
    hi some boot lids you cant get at from the inside
    best to do what some said and rip it out.
    or if you have 6 thin plastic wedges use the from the outside and try and push the metal clips in to release the light.
    Northampton
    i thought so as i pulled half the trim out to look at it but it seemed to be access to the brakelight.. cause i can rip the old 1 out n push the new 1 in...?
    May 2008
    Tyneside
    Check out this link link
    Northampton
    i finally done it.. there was no access from the inside so took the brakelight to pieces just to get it out lol
    heres a pic
  1. Signum clear 3rd breaklight
    By BYGino in forum Styling
    Last Post: 21st July 2012, 18:29
  2. Breaklight warning
    By preecy in forum Vectra C / Signum Troubleshooting
    Last Post: 18th March 2012, 08:51
  3. breaklight warning
    By bower in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 10:49
  4. rear tailgate griffin badge
    By Gordon Livsey in forum Bodywork & Interior
    Last Post: 6th October 2010, 10:32
  5. Rear Tailgate
    By Manni2375 in forum Bodywork & Interior
    Last Post: 1st October 2005, 10:49
