Results 1 to 10 of 17
Thread: 3.2 auto g/box going to neutral
    Yallah, NSW, Australia
    Default 3.2 auto g/box going to neutral
    Is there any way to stop the auto gearbox going into neutral when stopped? I find this extremely annoying as it is necessary to wait after taking my foot off the brake until the gearbox re-engages before accelerating. Failure to wait results in the gearbox engaging at higher revs which must be placing strain on the drivetrain.
    At present I engage the handbrake and take my foot off the brake to get it to stay in gear.
    This is an Australian (Holden) Vectra 3,2l. A great car to drive other than this truly awful feature.
    - John
    EVERYWHERE
    Quote Originally Posted by JG2530 View Post
    What does it say in the manual?
    From the manual:
    "Neutral Idle Control.
    This feature is designed to reduce fuel consumption. The automatic neutral shift function is activated when:
    - the shift lever is in D or manual mode
    - the foot brake is engaged
    - the vehicle is stationary
    - the accelerator pedal is not pressed, and
    - the transmission oil temperature is greater than 0 degrees C.
    Once the brake is released and the accelerator pedal engaged, the automatic neutral shift function is deactivated and the vehicle moves off in the usual maner."
    That is all the manual has to say on the subject.
    I like most other things about the car, actually the 3.2 litre engine with a manual gearbox would be great but I don't think they sold that combination in Australia.
    John
    Jul 2006
    Mexico
    All Vecs in Mexico had that "feaure" disabled....it causes more pains than goods......I´m almost sure you can turn off that with TECH II.
    HTH
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Feature is added to all newer Auto boxes by nearly ALL manufacturers to prevent burning out the torque converter, which is very costly to replace. On older auto boxes you are supposed to engage Neutral manually when stopped at traffic lights/heavy traffic.
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    This has been around a while now and I had it on all of my Auto Omegas from R reg upwards. I just put it in N at the lights or when waiting and then just into D when ready and off you go, easy.
    Mar 2011
    Bulgaria
    How can I found if my auto neutral working when logging. What I can see is when D is engaged, actual gear shift is 1-6, however never "neutral". Except if manually engaged Neutral.
    I was feeling the same 3 years ago when I got my car. It is my first auto-gear box car. Now I do not feel this anymore, Is it broken or I just used with this delay.
    Something more when my car should be on auto-Neutral my fuel consumption (0.9-1.4ltr/h) is higher then in Neutral (0.5-0.8l/hr), this causing my doubts if it really works.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    all auto vectra s and siggys do it leave it in drive when u stop u will feel it drop in to neutral lift your foot of you wilk then feels a slight jolt type thays back in drive tje display doesnt change unless u select neutral
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    In D when stopped it should be trying to creep against the brake.. It should take up drive quickly when you press the accelerator, if it isn't then your gearbox is ****ed. In N it is completely disengaged.
    So if you want a quicker getaway keep it in D. Other than that I don't get what you mean by "neutral" if you're not in N.
    Mar 2011
    Bulgaria
    When car is in "N" - neutral fuel consumption is less then when the car is:
    – The selector lever is in D or manual
    mode
    – The foot brake is depressed
    – The vehicle is stationary
    – The accelerator pedal is not actuated
    – Transmission oil temperature is
    over 0°C.
    Is it normal. When logging the car via OBD it showing Actual Gear from 1st to 6th but never neutral! Will upload log later...
  1. revs low in neutral
    By dan21 in forum Engine & Drivetrain
    Last Post: 8th August 2012, 19:25
  2. Auto Box "pulling" in neutral / when stood still
    By Paul H in forum Engine & Drivetrain
    Last Post: 20th November 2010, 13:50
  3. Auto neutral - again
    By Robert Greenway in forum Engine & Drivetrain
    Last Post: 15th January 2009, 22:03
  4. gearbox stuck in neutral
    By nobel in forum Engine & Drivetrain
    Last Post: 30th October 2008, 21:48
  5. stalling in neutral
    By woodylove101 in forum Engine & Drivetrain
    Last Post: 30th June 2008, 19:55
neutral idle control vectra c 3.2 v6
automatic gear box type in vectra c 3.2 v6
disable automatic neutral shift vectra
automatic neutral shift function opel vectra
how to disengage vectra c neutral at stop
