Thread: blank 2.2 dti diesel pump wanted ? help
    bradford
    Default blank 2.2 dti diesel pump wanted ? help
    i need a blank diesel pump for my 2.2 dti sri
    any one got one or know where i can get one
    i live in bradford west yorkshire
    cheers
    Bristol
    Why do you need a blank on. If you get a seconhand one with the same pump number it will fit on you your car with no programing.
    bradford
    no it wont , it needs to be tech 2 out of other car or you need cars security code trust me !
    Bristol
    Well I fiited one on my omega 2.2 dti and on a 2.0 dti no need for tec 2. How do you think all non franchise diesel garages change them then. They don't have tech 2. The only way you will get a blank one is to buy brand new an then they are coded to you ecu , there is no such thing as a blank pump . If you change the ecu on the car as long as you have key ecu and transponder from doner car its got to be the same part number ecu you do not need tech 2 .
