Results 1 to 10 of 19
Thread: Customer Satisfaction Program....
    spoons
    Guest
    Default Customer Satisfaction Program....
    Just to partially revive a classic
    Got a letter today and you gotta laugh....
    Blah Blah Blah....
    "During its extensive test programme, Vauxhall reviewed a number of handbrake mechanisms and found when the handbrake is incorrectly applied by depressing the release button, it is possible to manipulate the handbrake mechanism so as to cause it to release partially."
    Oh what !!.... please...
    result is to return the car to Vauxhall to have the modification carried out, so that the handbrake cannot be applied incorrectly. Its a button and a hinged bar... how hard can it be for crying out loud
    Their wording is correct, as they have used depressed and not pressed
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Use the handle properly spoons!!!! nice aircraft by the way, shame about the squadron!
    spoons
    Guest
    How can the driver be allowed to apply the hand brake by depressing the release button at the same time then? ... thats like Microsofts press 'Start' to shut down your computer.
    If the button is a 'release' button, the driver shouldnt be allowed to press it until the hand brake is applied correctly. Again a design fault.
    Either way Vauxhall...
    Sunny Dartmoor
    I had the same letter the other day,had the car for nearly 18 months....
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    It gets worse!
    The insignia as a Electronic one
    They cant even sort the std one and went for this all the way down the hill sooner or later
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Quote Originally Posted by spoons View Post
    Blah Blah Blah....
    Inside information suggests that if you're one of the well behaved people who do what they were taught when they learned to drive, and press the handbrake button when putting it on, rather than just wrenching it up, the pawl cat end up on the"peak" of the ratchet, rather than the "valley". It can then fall off the peak and fly off.
    If you just wrench it up, the problem won't occur.
    Phil
    Plymouth
    Quote Originally Posted by SignumPhil View Post
    Phil
    So Vx basically want us to do the opposite of what we were all taught... lol
    Luton, Beds
    Quote Originally Posted by Diet1985 View Post
    Or have the mod, which puts a stronger spring in the button.
    Phil
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    This is hardly news.
    The handbrake mechanism works like any other traditional handbrake. The only problem is that it is susceptible to failure depending on how it has been applied.
    I have said this on here many times, if the handbrake is applied correctly, then you have nothing to worry about. If you apply the handbrake with the button depressed, then there is a chance is will slip off and fail.
    I have always applied the handbrake like this, hold button in and pull up, then release button for the last 2 clicks - never had a HB fail on me.
    Mine is having the extra spring fitted next week anyway.
  1. can i program a used key?
    By vectraross in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2012, 11:56
  2. Owner Satisfaction Poll #2
    By Telly Addict in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2010, 23:24
  3. Old program used to be on ITV...
    By _ZS_ in forum General Chat
    Last Post: 4th December 2007, 23:33
