Results 1 to 10 of 11
Thread: Brake pads sensor
    Regular Member s1nglef1sh's Avatar
    Fife - Scotland
    Default Brake pads sensor
    At what point should the brake pad warning light come on?
    My brakes are grinding quite loudly now and I've been holding off getting new pads (and discs) until I get the warning on the dash. Problem is, there has been no light yet. The last visual inspection I had, I was told my discs were starting to lip so I know I'll need to replace the pads (and discs) soon
    Couple of questions:
    1. Is it possible that I don't have the sensor?
    2. If I order pads (and discs) from the stealers, do I need to request the sensor seperately, or does the old one plug in to the new pads?
    3. Is there a sensor on both front and rear pads?
    4. If I buy from someone like Brakes International, will they supply the sensor or will that need to be ordered seperately?
    Thanks guys
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    my pad sensor warning light never came on, when i changed the pads i pulled the sensor and it just perished....bought a new one and its being fitted the weekend
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I did not think all cars have them mate I know my Rear ones were really low and they did not flag up.
    I would get them replaced soon mate before you need new disks
    Fife - Scotland
    Quote Originally Posted by big rich View Post
    How much was it mate? I take it its quite cheap?
    Fife - Scotland
    Quote Originally Posted by Sean-2.2Direct View Post
    I'm pricing it up as we speak mate!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by s1nglef1sh View Post
    Thanks guys
    1. Doubtful - I thought all Vec-C's had them
    2. Yes - there are two different sensor looms, one longer than the other with different connections to the main harness. Give VX stealer your reg. no. and he'll tell you which one you need.
    3. Front n/s only, nothing on the rears
    4. Think you need to order the sensor separately in all cases
    HTH
    11 Post(s)
    According to the handbook, the brake wear sensors are an optional extra and not fitted as standard.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's easy to see the sensor wire on the n/s front wheel, just put full left lock on and have a look at the brake caliper.
    Just cos the disc has a lip, doesn't necessarily mean that it needs replacing. It is bound to get a lip formed as the disc does wear slightly over time, unless the disc is below it's minimum thickness then it would be fine to not replace.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    not all veccys have brake sensors on (or so i belive)
    if you have you may struggle to get them off to refit, so just order a new pair
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Only one sensor, NSF.
  1. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. Fit brake pad wear sensor without removing pads?
    By James24 in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2009, 21:41
  4. brake pads
    By tjsingh in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2007, 01:34
  5. brake sensor new disc and pads
    By DECO in forum Suspension, Wheels & Brakes
    Last Post: 8th September 2007, 19:58
