Thread: twitchy signum
    Regular Member Martybhoy's Avatar
    Motherwell
    Default twitchy signum
    is it just me or does anyone else find the signum twitchy in the corners? im guessing it might be because its 40ft long though, or is there something underlying? going to be lowering and changing the aloys, whats the best combo, eg lowered 40 on 18's etc.
    Also it wheel spins like a mofo, just put brand new rubber on the front and its still going. been putting it down to greasy roads.
    and finally, will vxr pads and discs fit the signum 2.0T or is there different calipers etc
    opinions greatly appreciated
    Marty
    WGAF#5
    hi mate,
    also running a 2.0turbo - depends on the corner and speed entry etc
    siggys aren'nt renowned for their cornering abilities, but then if you get yourself a copy of police roadcraft manual and drive to the system of bend assesments vanishing points and ease and squeeze, you will find you CAN drive faster and smoother and your cornering WILL improve !
    Northampton, UK
    My cars a bit twitchy at the moment on corners, but that because I've got play in my rear suspension bushes and control arms, so I need to get that sorted soon. I've just ordered these - http://www.potn.co.uk/p1253990.htm - Hopefully these will improve the ride. I have the design, which is 15mm lowered from the elite etc. To fit VXR equipment, you will need new calipers if your going bigger than the 302mm standard on the Signum 2.0T as the VXR's are 340mm or something like that, or do you mean the GSI spec 314mm? If so, either way, its new caalipers, carriers, discs etc...
    Motherwell
    so whats the best pad n disc combo then for standard set up
    marty
    Northampton, UK
    Quote Originally Posted by Martybhoy View Post
    marty
    I've only used VX own brand brakes and discs. So cant advise you on that one. I've heard that grooved discs are quite good?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    just a thought have a good check of your front springs,mine was sometimes like driving on glass,tryed alsorts still no joy,until this week i lowered the car and found a osf spring broken.no its all ok.
    Regular Member Marty 1888's Avatar
    Scotland
    Hey Marty,
    Imagine another Marty Celtic man on the threads!!!! My Signum is also a little twitchy but I put it down to them not being particularly happy scudding around bends. I agree with Bobby though.... get your springs checked.... mine broke on Monday and I've since found out they are renound for this.
    Mon the hoops!
  1. twitchy rear end
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2013, 17:51
  2. Really twitchy around corners
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2011, 22:33
  3. Vec C twitchy Front end
    By Grovercus1969 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 20:10
  4. Twitchy Rear End
    By Mini the Minx in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2010, 04:02
  5. Twitchy front end on 2.2 sri 03
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2009, 09:53
