Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: 3.2 fault codes
    Regular Member rayvo-gsi's Avatar
    warrington
    Default 3.2 fault codes
    Anybody know what these fault codes are 1614,1616,1613.I did the brake and accelarator thingy and came up with these.
    Melbourne, Australia
    P1613 = Immobiliser no or wrong signal
    P1614 = Wrong transponder key
    P1616 = CIM wrong environment identifier
    Regular Member CDXI_2003_AUS's Avatar
    If they are the faults, it looks like someone changed the CIM over from the original one and didn't get it tech 2'd into the car
    Blantyre
    Quote Originally Posted by rayvo-gsi View Post
    What brake and accelarator thingy
    It's where you hold down the accelerator and brake then turn your car on (not start ) and you can read out your fault codes. Works for the 3.2 Veccy C and the 2.6 Veccy B. Link to thread here. http://www.vectra-c.com/forum/showthread.php?t=44548
    Blantyre
    I see,
    Doesnt work on the 2.2 though
    Quote Originally Posted by spennny View Post
    I see,
    That saved me trying it, thanks m8.
    warrington
    surely if it had not been tech2 the car wouldnt do anything ie dash etc.
    Have you had any problems starting the car?
    warrington
    Quote Originally Posted by stevedee3 View Post
    Yep sometimes the padlock symbol comes up on the dash and the car is dead (imobiliser no cutting in)i have to keep putting the key in and out and eventually it will start.I have also noticed that when i put the key in the ignition and the padlock symbol shows if i then press the unlock button on the fob the car will start.
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
