Results 1 to 10 of 11
Thread: Temp Sensor
    Newcastle under Lyme
    Default Temp Sensor
    I've recently cut the lower grille out and replaced it with mesh. I removed my temp sensor and replaced it in the corner of the new grill with some glue from a glue gun. Its now running about 4 - 6 degrees warmer than it should be. Where is best to refit the temp sensor and how?
    bump
    Sunny Dartmoor
    Put it back in the middle,thats the only solution.......
    Quote Originally Posted by glenboy View Post
    A similar position to it's previous, then if you still have trouble you know it’s not that.
    Quite hard to put it back there as it had a clip to hold it in - which it doesnt now
    Quote Originally Posted by JSYSH466Y View Post
    I don't know how vulnerable the things are but if you used hot glue maybe this has damaged it?
    I considered that but it did have a case it and the glue got onto the case not the sensor (I think). Ill take a pic at teh weekend if I can.
    What do people do with their temp sensors when they change the grilles?
    Jul 2006
    Mexico
    As long as its near the fresh air coming from the front it does not matter....tho I think they are very sensitive...so if you changed its position probably its reading more the engine temp than the outside one.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by BlueRob View Post
    its showing engine heat aswell m8
    Cheers guys will remove at the weekend
  1. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2018, 03:02
  2. Outside Air temp sensor........
    By Mark@Elite in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2012, 16:20
  3. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  4. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
