Results 1 to 10 of 19
Thread: ECU/engine management Reset?
    Northampton
    Default ECU/engine management Reset?
    Hi All
    Just a quickie , i have just put a deposit on a vectra 3.2 elite auto which i collect next week , my question is my last auto was a mercedes 300e-24 and you were able to reset the engine managment with a combination of key movments in the ignition , the reason for asking is that i drove/tested 4 3.2 auto's in total 2 vectras and 2 signums,when driving i found that 1 vec and 1 sig felt really fruity and the other vec/sig quite sluggish (for a 3.2) so just wondered was it someting to do with the engine managment learning the style of the previous drivers and if i could reset it ?
    Thanks for any help in advance ( im sure i will be asking for more help when i pick her up)
    Northampton
    Sorry , in case it helps its a 2004 04
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just disconnect the battery for 20 mins and that will do the trick mate.
    Northampton
    Thanks much appreciated
    south wales
    can't see that making a difference to the performance
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    as rushy said disconnect battery. welcome to the forum.
    south wales
    i've never heard of an ecu learning how it get's driven,this can't be true i'll be my left ball on it
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by vectrac20tsri View Post
    Big Phil a GSi owner saw 20 odd bhp increase in the rollers before and after just from a reset. He had previously fitted a filter and upgraded zorst. The reset made the ECU relearn all its parameters. You will notice when the battery is disconnected the car runs like a bag of @@@@ for about 100 miles as it relearns.
    south wales
    yeah but thats after modifications,so your saying that a ecu learns how it's being driven and then looses power
    Vehicle : SRi
    Mileage : 137000
    Apparently CDTi's with boxes fitted need resetting now and again as the ECU compensates over time for the over fueling. I understand what you mean though. From first hand experience, I reset the ECU while clearing a fault code and my MPG went up 3-4 points. I had previously fitted a new stock filter about 1 month earlier. The ECU was obviously using base info still from the old filter. So all I'm saying is a good old spring doesn't do any harm as it seams the ECU takes an age to alter its parameters on its own.
  1. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  2. Reset Engine Management Light
    By guygreen in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 18:53
  3. Engine fault code reset
    By papz in forum Vectra C / Signum Troubleshooting
    Last Post: 21st June 2009, 18:44
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. Reset Engine Fault light
    By jamesr in forum Engine & Drivetrain
    Last Post: 13th December 2006, 11:47
vauxhall vectra engine management light reset
vectra c reset ecu
vauxhall vectra c engine management light reset
how to reset engine management light on vectra c
https:www.vectra-c.comforumshowthread.php71269-ECU-engine-management-Reset
opel vectra c 2.2 dti ecu location
reset ecu vectra cdti with ignituon
can you manually reset engine man light on vectra c
how long for vauxhall ecu to reset 2.2dti
vectra c eml reset
vauxhall vectra c ecu problems
opel vectra c 2.2 dti ecu reset
vauxhall vectra c how to wipe engine management light
how reset engine light on vectra c
vectra c reset engine management light
vectra c turn of eml
reset vectra c eml
switch off engine management light vectra c
how to reset ecu vectra c
opel vectra c 2.2 dti jak zresetować eku
vectra fault codes re set
Vectra c 2.2 dti ecu reset battery
08 vectra engine management reset
vectra ecu reset
vauxhall vectra exhaust emission warning light
