Results 1 to 10 of 14
Thread: Stereo removal help?
    Regular Member MarkiQon's Avatar
    South Shields
    Default Stereo removal help?
    recently bought a c elite with no radio code so i contacted vx and paid £20 for a new code only to find it's not the original stereo so obviously the code won't work, i phone my local vx dealer and they had a quick look but they couldn't remove it as the person that put it in have bent the pins! They want to charge me £40 plus vat for "removing the dash" my question is will i be able to get to the stereo by removing the centre console area and how hard is this?
    Full Member spennny's Avatar
    Blantyre
    You got a pic of it mate
    Regular Member P3tchy's Avatar
    Milton Keynes
    Its a pain in the arse if the pins are bent, I went round to help one of the guys off here, being sure i would get it out but not a chance, He had to take the dash apart and break some it to get it out.... I tried to get mine out while there and it was stuck fast as well.
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    get some radio keys first mate from halfords and have a go yourself they are only about £5 max
    South Shields
    Quote Originally Posted by spennny View Post
    here it is, i've ordered the keys off ebay to give it a go.
    Attachment 16453
    Regular Member poves's Avatar
    lancashire
    Pull the plastic tray out above cig lighter
    Then slide climate control unit out and disconnect the plug/s at rear
    pull the wooden strip off the dash ( just pops off)
    then remove the torx head screws from around the graphic display and withdraw the unit and blower vents .
    This should give enough room to get at it.
    Should only take ten mins to remove the stuff I mentioned .
    You can use anything to slide in the release slots , I used sparklers lol . Or a coat hanger .
    Looks to me like the 4 grub screws are in place. They'll need to be removed with an allen key before you can shove the removal tool down the holes.
    hull, east yorkshire
    i used 4 large rivits to remove mine to nite saved buying some keys, pull two of the top blanking caps off and gentely pull the head unit
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i used 4 block connector screwdrivers lol
    milton keynes
    if it stuck in there £40 is a result , I spent hours trying to get mine out eventually had to cut mine out. I am the person P3tchy came to try and have a go at.
  1. Stereo Removal
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2008, 16:42
  2. stereo removal HELP!!
    By whatthevecisup in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2008, 16:28
  3. help on stereo removal
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2007, 16:57
  4. removal of stereo
    By armoured farmer in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2005, 12:12
vectra stereo removal www.vectra-c.com
