Thread: which tyres
    Oct 2007
    LINCS
    Default which tyres
    hi i have got vectra cdti facelift with eagle nct 5 215/50r17 looking to replace tyres ,can i fit 225/45r17 tyres as they are listed in handbook in tyre pressures section ?the 225 size tyre is actually cheaper than the 215 so if they fit ok then i will get more tyre surface on the road at a cheaper price .
    Yup, it's one of the most common mods around mate. Just make sure you change at least 2 on the same axle, or all 4...
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have Goodyear F1 GSD3 225/45/17 all round on my car and they really have improved traction, except when there is snow on the ground.
    I also get alot more rear tyre noise coming into the cabin and quite alot of what I think is tramlining.
    Next time though I will look at another make but keep to the bigger size. Falken tyres get alot of praise on here
    Regular Member djr69uk's Avatar
    Midlands
    got the GSD3s here too... cheap, grippy, bit of road noise as said, but a much better tyre and will improve the ride.
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    I got kumho ecsta ku31's on mine cant fault them in the wet and dry and quiet too
    Cambridgeshire
    Quote Originally Posted by Daywalker View Post
    brilliant tyres for the price of them
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Bigger is'nt always better !
    Quote Originally Posted by pidge View Post
    The wider the tyre the more it will tram line over all the
    uneven surfaces, the reduction in the wall size can make
    for a harder ride to ! I've found the 215 50 17 are a good
    balance for the sri.
    Aug 2007
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    Quote Originally Posted by Kcs View Post
    Maybe but if you go to 225/45r17 then you get a wider choice and cheaper as well plus its only a smidgen difference between the sizes so wont make that much difference to the ride IMO
  3. More tyres....!
