Thread: How to remove an alternator?
    Regular Member strothrc's Avatar
    West Mids
    Default How to remove an alternator?
    Anyone know how to remove an alternator on a 1.9 cdti(2005)?
    Thanks!
    Regular Member badback's Avatar
    Runcorn
    I'm no mechanic but i watched my mate (who is) do mine a couple of weeks ago. He took O/S front wheel off and one of the splash gaurds so he could get at it. The airbox came off, then windscreen wipers so that he could get at the bolts holding the fuel filter on under the plastic vent. He just moved the filter out of the way didn't disconnect any pipes. Then brought the old alternator up from the back of the engine and vice versa. Not a job i fancy but it took him about an hour. Hope this helps. He disconnected the battery aswell and i didn't need to put the code back in the radio it worked as normal.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Yours must be full cambus then mate if you did not need to put the codes in
    Runcorn
    Should i be pleased with that coz i don't know what canbus is. LOL
    Apr 2008
    Liverpool
    Hmm so so full canbus is when you have the scoll buttons one your steering wheel and half canbus is with the 3 buttons either side of your wheel.
    Do a search on canbus you will be amazed there will be alot of stuff on it
    Runcorn
    Yep i have the scroll button on the steering wheel, i'll have a mooch about to gen up on canbus, Thank you.
  1. Alternator remove/replace query
    By Paul_O in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2010, 20:18
  2. Why did they remove this ??
    By rockh in forum Insignia car chat
    Last Post: 18th July 2009, 01:41
  3. cant remove cd from hu!
    By pogo in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2009, 22:54
  4. How do you remove
    By Triple Trouble in forum Engine & Drivetrain
    Last Post: 31st March 2008, 19:11
