Results 1 to 3 of 3
Thread: Springs Advice?
    Ashford, Kent
    Default Springs Advice?
    Hi there, Vectra C (2.0 DTI)
    hopeing someone can give me some advice on a couple of things,
    firsts things first, being a bit of a wally @ the carpark were work i dident realised that the car was grounding hitting exhasts i thought the noise was pressure pads at the bottom of the car park doohhh, shielding on the bottom of exhasts has come off is this mot failure? is it a whole new exhasts? and if so can someone recomend somewere south east/kent that would do it at a reasonable price, or aftermarket alternative
    next thing is my rear springs are squeking pretty bad, had a browse in the garage last night and they look fine just a bit of rust built up i think there is hairline cracks in the springs causing them to squeek. are they reasonably easy to change myself? and is there any aftermarket lowering springs anyone can recomend, i had a scout on google and can get a whole set for as little as £60 but would preffer to take some advice on this though.
    thanks, Once again
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Are you looking for a Lowering Kit of springs or some Stock springs?
    The squeaks could be the spring could also be the arm or the shock.
    GM springs on the vectra fre prone to snapping though so if you see a hairline crack it probably is broke.
    AS for springs i had a PI Spring only kit for £90 this lowered my Sri a further 30mm (45mm for non sri)
    Ride is fine as for fitting i had my mate do them rear ones arent hard to change front ones are abit harder if your not mechanically minded then i wouldnt attempt myself personally
    As for the exhaust is it just the cover/guard? if so i would assume you can buy a replacement from a scrapyard etc
    Ashford, Kent
    yep guard, but it was welded on
    no a plus side, learning to take it easy in car parks and over speed bumps
    previouse car was a mitsubushi pajero 2.8T it loved em, vectras dont lol
  1. Some quick advice (new springs)
    By scotty84 in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2011, 22:10
  2. Replies: 5
    Last Post: 21st July 2010, 16:14
  3. Lowering Springs Advice.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 08:48
  4. New front springs ADVICE PLEASE!!!
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 19:35
  5. PI Springs Advice
    By PIMM in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2007, 21:25
