Results 1 to 10 of 11
Thread: Bulb Replacement light on when lights off?? Help!!
    Leicester
    Default Bulb Replacement light on when lights off?? Help!!
    Hi All
    New to this site and would love some knowledge on this subject.
    I have my bulb replacement light that keeps coming on when my lights are off. The light seems to be coming on in a random order, no consistancy. However as soon as I turn my lights on the bulb replacement light goes out.
    Unsure on how to resove this.
    Ryan
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You don't have HiDs do you..?
    This is what my HiDs did when I first fitted them, I need to get the cancellers to stop it. But if you don't have HiDs then I'll shut up and go sit in the corner
    Regular Member ExclusivDoug's Avatar
    Windsor, Berks
    Mine had a similar issue the other day...My sidelight stopped working so i turned the lights off (it was quite light anyway) and the bulb replacement light stayed on. When i turned the engine on later that day the warning light wasn''t only off but the sidelight had started working again.
    Leicester
    No. Just standard.
    Windsor, Berks
    Does anyone know if that light come on constantly when the brake light fails?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i,m sure i read somewhere that the bulb warning light will come on when the filament is near to the end of its life....ppl have cked their bulbs and found them to be ok ..but a week or two later the bulb fails ...
    Quote Originally Posted by soulman View Post
    Leicester
    confused
    That would make sense as not long after the problem started I had a main headlight bulb go. However all the lights seem to work at present. What I can't understand is why the light only comes on when the lights are off!!!
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    hmmmmmmmmm cant answer that one sorry
    Regular Member mat100edt's Avatar
    south coast
    the car checks the bulbs evey few seconds so if you get the bulb out error come up you can push the end of you wiper stalk (like you would to select something from screen menu) and it will go away but in aprox 5-10 secs time it will come back when its checked that bulb again. as some one has said if your bulb is actually working then its more than likely due to go anytime soon.
  1. Bulb Replacement Light On When Lights Are OFF!
    By adam2628 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2012, 14:16
  2. side light bulb replacement
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2011, 01:10
  3. Bulb replacement light ?
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2008, 15:20
  4. need help with bulb replacement light
    By kev1983 in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2008, 10:35
