Results 1 to 10 of 17
Thread: brake pads
    Regular Member swainey's Avatar
    Newtown Powys
    Default brake pads
    are MINTEX brake pads any good ?
    Newtown Powys
    can anyone help im after, good after market rear brake pads for a 07 vectra sri
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    IIRC, Mintex supply VX.
    I bought some from Camskill - OK, they were the wrong size (my fault, partly and needed pads urgently) but before I sent them back, I compared them with the VX ones I got from a stealer - identical, even down to the VX/Saab part numbers but without the GM logo. HTH
    Have you looked at the Mintex website? On-line catalogue is very good for cross referencing. http://webshop.tecdoc.net/ows/en/6E7...dexFramesetJsp
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I have had Mintex on a previous car and took them off after about 1k and replaced with EBC personal choice at the end of the day.
    Nov 2007
    lancashire
    ive used them and still do, very similar to vx pads
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    i would not use mintex pads,i have seen their pads break up,i would only use genuine pads and they are not made by mintex
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i have used them before with no problems m8
    Apr 2006
    Suffolk
    I won't touch Mintex with a barge pole!!!
    I go with Lucas every time.
    May 2008
    Tyneside
    Bought some vauxhall pads and pretty sure they were made by Ferrodo. I've used Mintex and been satified, after all they are a market leader.
    Belfast
    Vauxhall pads are either Textar, Ferrodo or ATE depending on the type of pad.
    Wouldn't touch Mintex, they're far too hard, they're like putting bits of granite in your brakes, they squeel like a stuck pig, they glaze up and wear your discs.
    Either buy proper Vauxhall ones, or pick up a set of Apec pads. I use Apec pads all the time, they're clean, last well, and don't squeel. £20 a pair too.
  1. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  2. brake pads
    By HEP in forum Handling & Braking
    Last Post: 17th October 2008, 23:32
  3. brake pads
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 09:38
  4. brake pads
    By dwdwdw in forum Suspension, Wheels & Brakes
    Last Post: 5th September 2008, 10:25
  5. Brake Pads
    By phildews in forum Handling & Braking
    Last Post: 15th July 2007, 20:06
