Results 1 to 10 of 16
Thread: Trouble selecting 1st gear
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default Trouble selecting 1st gear
    Does anyone have the same problem selecting 1st gear, When i go to select 1st and push the gear lever over to the left and then push the gear lever straight foward it's as if it hits the gear cogs and won't go into first.
    I have to move it back a little then push the gear stick foward and it drops into 1st. Tryed to take some photos don't know if they make sense.
    This is with the gear stick in first (pulled up leather gear stick surround)
    Should there be an extra something were the arrow points stoping you pushing the gear stick over so far and making it line up with 1st gear.
    This photo is with me pushing over to left as if going to sellect 1st ,
    It hits the black plastic surround and if i push the gear stick foward it will not go into 1st gear.
    And this photo is of it in reverse with the leaver pulled up pushed far over to the left.
    The first photo is as if there should be something there to stop you pushing the gear lever over so far so it lines up with 1st gear.
    I some times have to put it in 2nd gear and push it straight foward to locate 1st gear.
    Car is vectra c, 2004, 1.9cdti 16v, 6 speed.
    Thanks..
    Jan 2008
    Irthlingborough
    Merseyside
    Its the same on mine too - think is just a trait of the 6 Speed 'box in the CDTI.
    A mate of mine in work has a 57 plate one with hardly any mileage on it, and his is stiff too.
    Not to be worried about IMO.
    Jan 2008
    Irthlingborough
    Cheers for that ...
    Cambridgeshire
    Quote Originally Posted by signum_1.9 View Post
    mine does this occassionaly as well. I just lift off the clutch and start again and it's fine
    Had a similar problem with my old 2.2 DTi Veccy - wouldn't go into reverse without a lot of trying and clutch lifting etc. It would just refuse to go in...
    Turned out to be the reverse synchro. Still got the little ba***rding thing on my desk to teach me a lesson about buying cars with known problems...
    Jan 2008
    Irthlingborough
    It's not that it's stiff to get into 1st more that it will not line up with 1st gear so even if i lift the clutch and push it down again it makes no differance if you push your gear leaver over far left with clutch in then push foward keeping pushed over to left does it slot into 1st ,if i do this with mine it will not go into 1st it just hits and goes no wear.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like the bowden cable needs adjusting mate.
    Jan 2008
    Irthlingborough
    Bowden who what £££
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The cables from the bottom of your gear stick to the gear box. They will need adjusting, just like gear cables on mountain bikes do.
  1. Replies: 7
    Last Post: 2nd September 2012, 21:00
  2. Top gear in trouble again
    By new boy in forum The 'Off Topic' room
    Last Post: 14th January 2012, 01:58
  3. Top Gear in trouble again!!!!!!!
    By bigboynigs in forum General Chat
    Last Post: 5th August 2011, 13:07
  4. Trouble with the gear on my signum
    By LilleN in forum Engine & Drivetrain
    Last Post: 21st January 2011, 15:43
  5. trouble getting in gear
    By markocarlo in forum Engine & Drivetrain
    Last Post: 19th January 2011, 18:52
vauhall zafira 1.8 petol sticks in first gear
struggling to get reverse and first vectra sri cdti
vectra c facelift sri wont go into 3rd
vauxhall insignina how to get into the gears stick
vauxhall zafira wont go into 1st gear
vauxhall astra wont go into 1st gear
2006 vectra gear stick
VAUXHALL VECTRA 1ST GEAR ISSUE
gears not selecting vaxhuall zafira 2011
opel zafira 1st and 2nd gear selector problem
vectra c hard to get into gear
vectra dti hard to put in gear
z22se not going into first gear
vauxhall wont go into first gear
vauxhall zafira 2009 not going into 1st gear
vauxhall vectra c wont go into gear
vectra c hot first gear
vectra 1.8 wont select 1st gear
problem 1 st gear opel astra
