Results 1 to 10 of 25
Thread: Strut Brace for veccy c?!
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Default Strut Brace for veccy c?!
    Cheeck this out guys -http://www.yatego.com/carkonzept/p,42fb4ee17e982,42f0bead52b742_3,domstrebe-aus-alu-f%C3%BCr-opel-vectra-c
    Any Germans about? lol
    Regular Member cpt slow's Avatar
    In a house
    http://www.yatego.com/carkonzept/p,4...-opel-vectra-c
    Here is the correct URL , thanks for the post !
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by caprimanuk
    Nice one mate, cheers
    In a house
    No problem .
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Is it worth buying one? I have never had one so not sure.
    rough translation...
    Wiechers Domstrebe out of Alu, ahead above for Opel Vectra C
    High-value materials and processing guarantee are a long service life picture pictures pattern the manufacturer reference: Double tube three hurried Domstrebe, is secured on available devices on the cathedrals. In improper assembly, no liability is received! An improvement of the load behavior is supposed to be reached by the use of Domstreben and QuerlenkerabstŁtzungen. Domstreben are secured and prevent distortions of the load work between the front and/or rear suspension strut cathedrals, provide therefore for larger stability especially in curve trips. Domstreben are an ideal supplement to sport load works and wide tire and for almost each vehicle type available (Sonderanfertigungen by request). QuerlenkerabstŁtzungen improve the trace faithful and Lenkgenauigkeit, above all in higher speeds. A combination of Domstreben and breadth handlebars causes a higher measure at security, that not only sporting drivers should use.
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Hmm, dnt know if I understand that. lol
    Regular Member Meriva OPC's Avatar
    Jan 2006
    Just Chilling
    weichers strutbrace for an opel vectra C made in aluminium
    1. best grade material used giving you a long life guarantee
    2. Picture above is a sample
    3. Attention. the three piece twin pipe strut brace attatches to the existing mounting domes.
    4. They will not be held responsible if you install it incorrectly.
    The strut brace is used for improving the load behaviour (roadhandling) of your car. when fitted to your car they improve the handling especially going through curves, or for cars with bigger wheels. it will also improve the road holding of your vehicle at higher speeds and are for nearly all models not only fitted just for sporty cars. they will also make you one to your specification...basically translated.
    QuerlenkerabstŁtzungen - cross steering support (cross member)
    Domstreben - strut brace
    Armoured Farmer - Dein Deutsche ist nicht sehr gut, aber witzig zu lesen
    (mache nur spass)
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Cheers TrophyBlue, might call on your help again. lol
    Jan 2006
    Just Chilling
    I'm off to Germany next week for Easter so I'll look into it, after seeing the site I might indulge in one. I had one on an A4, it allowed me to get round corners 10-15mph quicker and just generally stiffened the front a little. Not really that much at lower speeds just when your caning it
  1. strut brace
    By adfrodsham in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 16:04
  2. Vec C Strut Brace
    By DarrenLee in forum Handling & Braking
    Last Post: 3rd March 2008, 23:35
  3. Strut brace .....WOO HOO!!
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2008, 00:27
