Thread: would this cause my spanner light to come on
    preston
    Default would this cause my spanner light to come on
    Spanner light has been coming on for a couple of minutes in a morning then goes off, when I turn ignition off and on again, the light does not reappear. There is no effect on the running of the car i.e. no loss of power, lumpiness etc. Took the EGR valve off today and found this lot inside, solenoid plunger was free to move but gave the whole thing a good clean, its done 99k miles so was due a decoke anyway, but would this be the cause of the spanner light? Its a cdti 120, was going to check the glow plugs but they look buried as thought they could be at fault.
    Plymouth
    thats the dirtiest egr ive ever seen!!!!
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    holy god. thats dirty. now im thinking a should be taking mine off the clean. jst over 90k and i recon its never been done.
    preston
    Even though there didn't appear to be any probs before cleaning, there certainly is a difference in driving now,its as though the car has just cleared its throat, sowt a speak. Much smoother acceleration.
    EVERYWHERE
    Quote Originally Posted by bygumlad View Post
    Sometimes the EGR valve will remain slightly open (due to carbon build up) without registering a fault or may show an occasional flicker.Even a slight seepage of Exhaust gas will dilute your fuel mixture,particularly at full load,full throttle and at idle when the valve should be completely shut.
    preston
    Sorted the spanner light and it was these little devils, glow plugs. Took car to Precision Engines of Doncaster who diagnosed and replaced the plugs for me. just tried it this morning and no spanner light on. I assisted in replacing them and if you want to do the job you'll need a 1/4" drive 10mm long socket, long extension that has a 1/4 drive that allows for slight misalignment of socket. A telescopic magnet for picking up stuff when you drop it and you will. A couple of long screw drivers to remove an replace the connectors and away you go! Takes about an hour.The hardest bit is replacing the connectors.
    There is no visible breaking up of the plugs like you used to get with older diesels so I suspect its a voltage drop issue its picked up.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
