Thread: engine temp sensor
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default engine temp sensor
    right mine is going from 80-0 all the time whre is it located so I can give it a slap and then clean it?
    its a 03 1.8 z18xe cheers
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    find the top rad hose and follow it to the engine block theres a conector above it thats you temp sensor
    Full Member Big Sig's Avatar
    Top left hand side - drivers side. IIRC its in the thermostat housing.
    Regular Member DKM's Avatar
    May 2008
    Suffolk
    Glad thats come up my 1.8 is the same, i thought it was this cold weather wiv had.
    guess i'l have to do the same to my sensor.
    Also the thermostsat is a weak point on the z18xe. It has a habit of sticking at around 45k, the whole assembly comes as one from the dealers - thermostst, housing and sensor
    May 2008
    Suffolk
    So it may well be mine is stuck open, i've done 60k?
    That'll be another job for me when weather improves!
    Thanks for the info m8
    Well it could be but it may not be - little disclaimer . Mine was stuck on my astra, used to take ages to get up to temp and then with a bit of driving would drop right back again. It used loads of fuel too as it thought it was cold all the time so it ran rich.
    If you do replace it, you will need to do the coolant at the same time as it will go all over the floor!
    May 2008
    Suffolk
    Well i can still have a tinker, or just see how it responds to milder weather over the next month or so.
    I'l change the whole coolant for new out of principle if i do it.
  1. engine temp sensor
    By daddyjay in forum Engine & Drivetrain
    Last Post: 4th April 2012, 18:03
  2. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  3. engine temp sensor location
    By CHRIS MCKEOWN in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd October 2010, 00:09
  4. Where's the outside air temp sensor??
    By cooky in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2010, 22:32
  5. engine coolant temp. sensor
    By Morephun in forum Engine & Drivetrain
    Last Post: 10th September 2008, 10:48
