Thread: Help seat belt warning light
    wolverhampton
    Default Help seat belt warning light
    Hi driving into work this morning my seat belt light came on and the beeper started going off for no reason. tryed ejecting belt and re fitting but still beeping.has this happened to anyone else and how can it be fixed?
    any help would be great the beeper is doing my head in.
    Full Member Big Sig's Avatar
    driver side or passenger side? It works with a switch in the base of the seat. If you had something heavy on the seat that might set it off.
    wolverhampton
    drivers side mate.
    May 2008
    Tyneside
    There must be a switch inside the buckle which signals the seat belt is fastened. The most likely cause is the connector under the seat is not connecting properly. Try disconnecting / reconnecting this connector which may solve the problem. This connector also causes trouble with the pre-tensioners usualy when the seat has been adjusted.
    I also believe it can be tech 2'd off
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    dont have anything beeping or anything in my vec.
    wolverhampton
    is this a main dealer job to have it switched off or dose anyone know somewhere in wolverhampton where i can get it done?
    Engine : 2.2 Direct
    its a job for someone that has a tech2 machine.. (Dealers have them)
    milton keynes
    Quote Originally Posted by steve-wolves View Post
    no need , if you dont want it to illuminate on the dash just unplug it under the seat. I woulkd disconnect the battery for 15 mins first , just in case you set off an air bag
    I came accross this by accident when i replaced my interior , the new seats i have put in dont have the extra connector , and i dont get the warning symbol now.
  1. seat belt warning buzzer
    By mabski in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 10:40
  2. seat belt light and seat occupancy recognition
    By xc600 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 20:26
  3. Seat belt warning
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2009, 22:30
  4. Temp Gauge & Seat Belt Warning
    By Oscar Ding Ding in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2007, 20:12
  5. seat belt warning not on
    By IanW in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2007, 07:35
