Thread: abs light
    greenock
    Default abs light
    after some heavy breaking the abs light in my car is now on and the abs isnt working
    could this be a sign that the pads or disks need changing?
    or is it something more major?
    57 cdti?
    Jul 2006
    Mexico
    To my knowledge only the hand brake light turns on when pads needs changing.
    A proper code reading might be needed.
    HTH
    Regular Member Robclowes's Avatar
    Oct 2007
    Crewe/Market Drayton
    I also had this happen and needed a new hub!!!
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Most likely the abs sensors are unable to read correct wheel speed. Happened to me after wheel spin trying to get out of street in Snow. Just turn off and then drive the car and sensors should re-teach and read wheel speed-mine did took about 5-10 miles.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Could be the speed sensor wiring connector has got water in it. Fairly common problem for the front left wheel. Have a look behind the hub and you will see the sensor wire clipped into the suspension leg. Disconnect the wiring plug and see if there is water in it, dry and refit may solve the problem. Worth doing on both fronts.
    Regular Member DKM's Avatar
    May 2008
    Suffolk
    Yep, ste hit the nail on the head, mine had water in the connection and caused abs light to show.
    I squirted some WD-40 in there, no problem since.
    greenock
    went in the car today and its fixed itself lol!
    maybe the water drained out? but its deffo working now
    Regular Member dan mann's Avatar
    Jun 2006
    Never in one location for long
    These things can happen.
    Jul 2006
    Mexico
    The more gadgets a car has the more glitches.
    Glad its sorted.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
2006 vectra c abs light on
