Results 1 to 10 of 17
Thread: Annoying rattle
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Annoying rattle
    HI.
    Im hearing an annoying metallic rattle whilst driving with windows down.
    Looked as suspension, looks okay.
    Looded at radiator area, as I think its coming from there.
    On the car there seems to be two layers of the radiator, with the front part slotted in the bottom and screwed on the top. Should there be screws in the bottom as it appears the bottom right corner of this front part is movable to the extent it bangs on the radiator causing a metallic sound.
    Any help greatly appreciated.
    Russ
    Plymouth
    is there a rattle when its idling???
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by Diet1985 View Post
    no mate, only when the wheel hits a bump in the road, and it doesnt matter which wheel hits the hole/bump the sound is exactly the same, which is why im suspecting this radiator thing.
    but i can physically move this front part of radiator, as if it should be screwed to the main radiator body.
    Plymouth
    to test the rad... get someone to start up the motor and stick your ear near the rad.... as it will start it will rattle to high heaven.... if u can hear it then, then it will be the rad... if not its something else.
    Mar 2007
    Grimsby, Lincs.
    will try that. it may also help if someone is willing to just pop their bonnet and check if this front part is screwed in on their car or if they can move theirs to the point it makes contact the main radiator body.
    Mar 2007
    Grimsby, Lincs.
    please lol
    Plymouth
    i cannot at the mo. as too busy and im only sneaking on here... i will later though if noone else cant
    Regular Member Signum Mad's Avatar
    Lisburn
    I had a slight noise the same, was mainly when i hit speed bumps. also new a fella with a Vectra C est he had same noise as me and he replaced strut tops, which cured. You could try that.
    Mar 2007
    Grimsby, Lincs.
    will look into that.
    but i still need too know if the radiator should be more rigid
    Mar 2007
    Grimsby, Lincs.
    bump.
  1. Annoying Rattle - help!
    By Davies20 in forum Bodywork & Interior
    Last Post: 3rd May 2010, 11:55
  2. annoying rattle
    By jay5041 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 22:15
  3. really annoying rattle
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2008, 18:57
  4. Annoying rattle
    By Tigger in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2008, 11:03
  5. Annoying Rattle
    By ANDY GSI in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2007, 18:04
